Anyone run a 9800pro on 200watts here?
NeO_TeTSuo
I wanna get that His 9800pro ice card. Im running a 9500pro right now runs great but I need a better card just wanted to know if I can. I cant upgrade my psu cause its the micro atx only thing on my pc thats power hungry is a video card.
My brother has a 9800P and he runs it in his Shuttle, as well. :D
I wouldnt think so. My 9600xt wouldnt work with a 230watt psu
I would think he meant it doesn't require a power connector from the PSU directly? :D
On a side note, being able to use your current one would largely depend on if it is a quality PSU or not.
My 9700Pro, works fine with my Mini's 200 watt PSU. I acctually heard that the PSU Biostar uses can even handle the Geforce 6800 ULTRA. I agree, quality is the most important factor, I'd rather have a 350watt Antec/Enermax PSU over a 500watt Deer PSU any day of the week.
HP offers a 9800 card as an upgrade so I figure I should be able to get the pro, and yes I did mean the psu connector
Check my sig...granted, the power supply is 220 watt but I think that with the overclocking and extra hard drive it would be comparable to putting a 9800 Pro on a 200 watt PSU.
what do you mean by power quality? I have 2 HD's, CD/RW, 9800 Pro and video capture card....more USB devices than I care to think of and have never had an issue with the unit all running on a 200W PSU so I guess you don't have to use one of those monster 6TWatt PSU's on your comp afterall
how is it possible to run that thing when most other systems the radeon 9800 likes 350 Watt & up PSU'S??? can it cook a hamburger yet? (hot?)
My SHuttle SN41G2 has a 9800 pro with only a 200watt PSU. And it runs fine. It is even oc. 2500 to 2800+, 1gb PC3200, 2HD and 1 DVD/CDR.
my friend has a shuttle with a 200 watt PSU on a BBA 9800 pro and it runs fine on stock ( he does crash alot when he oc's though ).
Same here. Though you mention an overclock to 2800+, yet in your sig it says 3200+... I'm curious as to which is right because I can't get my 2500+ up to 3200+ speeds and I'm running PC3200.
SO OBVIOUSLY it IS possible to run the Radeon 9800 PRO on a 200 Watt PSU, but how is your stability and heat? I can only imagine it sounding like a bug light and throwing heat like half f%$#ed fox in a forest fire.
