Anyone recommend a fan splitter?
big_aug
I'll have 9 total connections. Four case fans, four radiator fans, and one radiator pump connection. I just need a splitter or two for cable management. I don't care if fans run full speed all the time. There are lots of these out there, but I figured someone might recommend something specific.
I thought about getting this: http://www.frozencpu.com/products/2...plitter_-_SATA_Power_8W-PWM-SPL-ST.html#blank
My fans aren't PWM but this should still work though, correct? This would let me get all 8 fans connected in one connection.
IMy fans aren't PWM but this should still work though, correct?
It will power 3-pin fans, and you'll even get RPM monitoring from the fan on the primary connector... but, there's one major caveat.
Using that adapter with 3-pin fans would result in all fans running at 100% speed at all times. You might as well just connect them all directly to the PSU.
