Anyone OCing mATX s754?
Ruiner
Per subject:
list results, chipset, cooling, plus max vcore/vmem/fsb settings.
k'thx
Since I probably won't look at this thread again...
Currently:
CPU: 3400+ DTR ('CG')
Chipset: nForce3 250
Cooling: Swiftech MCX64-V & 80mm @ 2200RPMs, 2*120mm 1700RPM fans, 1*120mm 1300RPM PSU Fan, 1*80x10mm 625RPMs & Silencer on vid card
VCORE: 1.55v
VMEM: 2.7v
Results: 2.4GHz, 240fsb, 2.5-3-3-7
Probable:
VCORE: 1.65v
VMEM: 2.8v
Results: 2.5GHz 260-265fsb, 2.5-3-3-7
^ Tested the max on everything individually, but waiting on PSU to confirm.
Didn't know there was a mATX Nforce3 250? I thought they were mostly K8T800, K8M800 or the SiS chipsets with Apoen having the only Nforce3 board.
Currently:
VCORE: 1.55v
VMEM: 2.7v
Probable:
VCORE: 1.65v
VMEM: 2.8v
The mobo listed in your sig comes up as a full atx. I can't find any 939 micro boards at all, and all the 754 micros are via's.
Dillusion what HTT speed did you get up to for the 2.3ghz? Was it 230?
