Anyone know where to get circular cable grommets?
Smoblikat
Hello, im trying to find a half inch cable grommet with the triangle teeth, but I havent been able to find anything like what im looking for. This is an example of what im trying to find:
That little tiny one on the side is a bit too big for my needs, but its not far off (I do have a HAF 912 I could "borrow" from if need be). It just needs to be big enough to fit a 4 pin fan cable through, which I believe is about .4 inches.
I appreciate any help you can provide.
That is the back of a Coolermaster Haf 912 case or a Enforcer case both collectors items according to ebay.
Good call, I was able to find these:
https://www.primochill.com/products/primochill-1-2-inch-cable-tubing-rubber-pass-thru-grommet
But they dont have the triangle flaps that im looking for :/
not sure if youll find ones that small with "teeth", usually those are 3/4" and up.
edit: might need to get "closed" or "blind" ones in the size you need and cut your own "teeth"
https://www.ebay.co.uk/itm/Rubber-G...osed-Grommet-Plugs-Bung-6mm-50mm/262281562555
https://www.amazon.ca/PV510M-Grommet-100-Diaphragm-Polyvinylchloride/dp/B07QJWYNKM
Amazing, thanks for the help, i was able to find an ebay store with a whole bunch of sizes to pick from. Im going to get the solid ones and then just cut my own triangles into it, that should work out well.
https://www.ebay.com/itm/352379375471?hash=item520b728f6f:g:mW8AAOSweRlasn1f
GB12 is 12.3mm, which is just under half an inch, so that will work out great as I think I only need .4.
