Anyone know where to get 193p?
bob321
Hey Everyone,
I was trying to locate a Samsung 193p, but I can't find one anywhere. I also don't live in the US, so I need somewhere that will at least accept payment by wire transfer. Newegg used to have them but they went out of stock and then disappeared from the list.
One online store I usually buy from has the 191t+ . Does anyone know how the 191t+ compares to the 193p. I don't really care about the fancy bezel, just the colour accuracy and the viewing angle, and a little about ghosting (I only play Need for Speed Underground) and dead pixels.
Thank You
I think that the 193p is supposed to be a lot better than the 191t+ in terms over color, viewing angle, response time. I can't really tell you for sure but I think the 193P is supposed to be a big improvement over the 191t and 192t.
Thanks for the info,
I found it for sale, but it was $797 which out of my price range.
Does anyone know of the Samsung 173P is worth the extra money as it costs about the same or close to most 19" LCDs?
Thanks
