anyone know much about Dishnet's HD-DVR's?
rage4order
Here's the deal, I have a Dish Network HD-DVR that just went out on me. I plug it in and it does nothing but all I hear is the internal fan running. So, my predicament is, I have stuff recorded on there that I'd like to recover. I have a replacement on it's way, so I went ahead and opened this one up to see if I could hook up the HDD to my computer and get my recordings like that. Well, when I connect it, the HDD doesn't do anything and doesn't show up in my pc. I have it plugged into my pc thru an SATA card, but am powering it with the satellite box. Does this mean the HDD is bad, or could the power supplying the HDD have gone bad? Does anyone know if what I'm trying to do is actually possible?
Sorry if this is in the wrong forum...
even if it worked you wouldnt be able to see it.. since they use a different formating/code on the drives.. and most likely the hard did die.. ive killed 8 hard drives on my comcast Motorola box's in the last 2 years.. they are cheap hard drives and id bet they are the same drives dishnetwork and directv use.. just something you have to deal with..
Ok, thanks. That's what I was afraid of. I did pull the drive already and it's a Western Digital. This is my 5th receiver in 2 years already! :mad: Sure sucks that they make a crappy product like this, yet don't allow you any way of backing up your shows...unless you pay them their $35 to "activate" the USB port... :rolleyes:
there should be a firewire port on the back.. if it does you can also backup your recordings that way.. but can only play them in vista WMP..
