Anyone Know how to use MyLogo.exe?
Hamfiles
I have an Asus P4P800-E, and it comes with the Asus MyLogo software. I would like to use a custom logo for the Bios image, but I don't know how to do this, and there is no help file that I can see.
Has anyone here ever used MyLogo.exe?
Thanks for any replies,
-Hamfiles-
What you are basically doing is taking an image at a specific res and creating a new bios bin to flash. You flash it voila! new image at boot. I would check and make sure your bios is up to date if not grab the update and throw your new logo in and flash it.
Thanks, I will give it a try. Hopefully I can open the new bios file using MyLogo.
