I got a new laptop (Gigabyte Aero 15) which has a GTX 1060 that uses nVidia Optimus switching. All works well overall, both the iGPU and dGPU function and perform as they should. However it does have an annoying issue that when I launch some things, like a UAC prompt or the task manager it hitches, input stops responding for a second, then continues. Looking at it, this appearts to be an Optimus issue. The dGPU fires up for a sec to see if it should handle it, then goes back down, and while that is happening the system hangs.
Anyone else encountered this and have a fix for it? So far I've not been able to find a way to make it stop.
