anyone know a proxy for myspace.com
True enough. Any proxy would do. However... I'd recommend against using one. I assume you're at school or work, and they have software/hardware set up to block those sites. Chances are that not only will that setup catch most attempts at work-arounds, but also land you in hot water.
Is it really so necessary for you to surf MySpace that it can't wait until you get home? :rolleyes: Answer is probably no.
If it's for circumventing anything from your school/work/whatever, we can't discuss it. You will have to find your own solution or just, you know, do something more worthwhile until you get home.
Man, I gotta fill out those questionaires about myself, or I might get some bad luck!
Indeed, don't circumvent your school/work's internet policy. We... er.. they will catch you.
All hail the mighty logfile! *oohhhm*
