Anyone know a laser cutting service?
Where are you located? You will probably have the best luck looking for some place local.
Im in minnesota, Its kind of a pain, I just dont have a good hand with metal work, nor the tools here for a nice clean cut.
Also consider waterjet cutting. Find some one local, shipping would increase the cost a lot if done by a forum member.
call up a local machine shop and see if they can cut it for you.
Plasma cutter works great too, had my friend cut a hole in my thick steel case with one a few years back.
