hi friends I'm a noob here, but an old one...
Question: I'm foolishly trying to turn a Win7 [or it could be XP if need be] Aopen XCcube into a HTPC... And the first issue I'm having is the absence of support from Aopen.
If any of you have been down this road and could help I would be appreciative.
The model I'm playing with is a MZ915-M Black shoebox. It actually works pretty good considering that the BIOS doesn't seem to have actually been written for that exact mobo rofl..... There are things in the BIOS that just defy logic, like no mention of SATA devices though there are four headers on the board, and they almost work.
When I check their websites, I see no BIOS releases other than the original one.
Apparently there is something about the BIOS and video that do not jive... I use Paragon Backup & Recovery on my other systems and it works well for moving a Windows 7 image over to new hard drives without damage, among other things. But the recovery media won't run on the Aopen box due to it failing to properly identify video, or a video mode it can run with. Secondly, I can't get around that easily because though the box has 4 SATA devices connectors, only the first bank works, and I suspect the reason is that the BIOS doesn't know how to run on the other bank.
Is there another model perhaps that uses the same MOBO as mine, and perhaps has a BIOS I could use that would be appropriate to the devices in the system?
Any/all tips you could give will be greatly appreciated.
C
C
