Anyone having trouble getting regular SMP work?
mplee
I haven't been able to get any regular SMP work on 3 clients so far. They've been retrying for the last hour or so....
Code:
[22:09:38] Connecting to http://assign.stanford.edu:8080/
[22:09:38] Posted data.
[22:09:38] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[22:09:38] + Couldn't get work instructions.
[22:09:38] - Attempt #8  to get work failed, and no other work to do.
Waiting before retry.
[22:19:43] - Autosending finished units... [September 15 22:19:43 UTC]
[22:19:43] Trying to send all finished work units
[22:19:43] + No unsent completed units remaining.
[22:19:43] - Autosend completed
[22:20:31] + Attempting to get work packet
[22:20:31] Passkey found
[22:20:31] - Will indicate memory of 3993 MB
[22:20:31] - Connecting to assignment server
[22:20:31] Connecting to http://assign.stanford.edu:8080/
[22:20:31] Posted data.
[22:20:31] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[22:20:31] + Couldn't get work instructions.
[22:20:31] - Attempt #9  to get work failed, and no other work to do.
[22:41:58] + Attempting to get work packet
[22:41:58] Passkey found
[22:41:58] - Will indicate memory of 3993 MB
[22:41:58] - Connecting to assignment server
[22:41:58] Connecting to http://assign.stanford.edu:8080/
[22:41:58] Posted data.
[22:41:58] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[22:41:58] + Couldn't get work instructions.
[22:41:58] - Attempt #10  to get work failed, and no other work to do.
lmao, maybe thats why I finally got a 2686 today :)
My SR-2 can't get work either - that would be a bigadv request. I have another one ready to drop in 30 minutes...
Maybe with all the ramping, Stanford can't keep up with us?
just for shits and giggles check your system clock and make sure its correct.. ive had it happen a few times where ive accidentally changed the date and boom no WU's..
Getting on average 2 SMP units between each bigadv unit, but still getting them.
It's not limited to SMP. I have an SMP2 and Uniprocessor client unable to get work.
GPUs seem to be fine though...server status looks fine as well...
I can't get SMP or bigadv work on any of my clients. My GPU client just picked up a WU about 20 minutes ago though.
I guess the assignment servers, at least whatever ones deal with CPU clients, are broken. Hopefully it won't take them too long to get them back up.
Haven't seen a bigadv for 860 in 4 days. As for this, all 3 smps that I run are waiting for work for the past hour now, figures they would all finish around the same time when servers go down!
I'm getting the same issue, I reset the client and it said this BEFORE the log started (Hand copied from a screen shot because I'm too lazy to throw it on the net):
Unable to connect to 'Justin-PC:8676', sock error: generic socket failure, error stack:
MPIDU_Sock_post connect(1228):unable to connect to Justin-PC on port 8676 exhausted all endpoints (errorno -1)
MIDU_Socl_post_connect(1275): unable to connect to Justin-PC on port 8676, No connection could be made because the target machine actively reused it. (error no10061)
--- Opening log file blahblahblahblah cant connect blah blah blah
Nothing here either. I put my second 465 back online this afternoon so at least I'll be folding something.
ok looks like their servers went kaput.. damn this is going to be a low producing day for F@H.. good job PG :p lol jk..
Server status page shows most servers are up but looking at psummary, there is no available SMP or classic client work available. Something is not communicating properly @ Stanford.
We should leave the client running though, right? To catch the servers when they come up.
wouldnt know, ive got a longggggg time left on my current WU(18 min TPF, its a 6040....) ill let ya know in roughly a day lol
Did someone trip over the 10base T ring cable over there again?
Heh, there's a part of me that wants to deny this statement, but ya know, I can see this being a situation there...:rolleyes:
Sorry it was me.. I was out of coffee and the fastest way to the break room is through the server room... :rolleyes:
Got home from work about 20 minutes ago to no work and the unable to connect to server message. Shut the client down and restarted it and pulled down a 2686 :D
Code:
Yes but plenty GPU work.
