Anyone having issues with Intel Burn Test & Win7 64?
lodingi
When ever I setup a multipass run of IBT, the "success" box pops up after a single pass. I didn't have this problem with Vista 64. Enabling compatibility mode didn't help. Anyone else experiencing this problem?
only thing i can say is check your settings and make sure its not set to only run 1 pass.. but havent seen anyone with issues though im only running it on w7 32bit..
what are your other settings?
how many threads?
what stress level?
how much ram do you actually have versus how much you're letting IBT utilize?
i find i get the best and most accurate results if i manually set the number of threads i want to use. and i always run maximum stress so as to use a majority of my available ram. if you use the very high setting instead of maximum, IBT will often try to use more ram than you actually have.
