I just bought a pair off Newegg for $90 on sale. It seemed like a good deal but there are so many problems with them.
After installing the software, I plug them in, I get sound, and it seems to work OK. Then every 10 mins or so, they shut off and reconnect for no reason. Also, the software doesn't show that surround is enabled, and doesn't display the battery life. The software is also ridiculously slow, constantly freezes up and crashes.
So I uninstalled it, rolled back to the older version that came with it, and got the same thing. I tried their beta drivers, got the same results.
I checked on their support forums and it seems like lots of people are having similar issues and most of them are not getting resolutions so they're just returning them. I thought maybe some of the gurus on here might have some suggestions. Any help would be appreciated.
I am running Win 7 Home 64bit, and apparently these things do not like Win 7 64bit. I have no sound card, I am plugging the transceiver unit directly into the computer, no hubs, all my drivers for everything else are fully updated.
