Spacy9
Scotch is my Lord and Savior
- Oct 13, 2000
My Home theater room is Approximately 14' X 18', or about 252 sq ft. It has 9 foot ceilings and is in the basement. The room has 7 seats and it does have one AC/Heater vent in the ceiling and one return.
80% of the time there are only the 4 of us, or the kids with their friends watching a movie and the temperature is still bearable by the end of the movie. However if family is over and we have all 7 seats filled it gets pretty toasty in there, even with the whole home AC on.
I've been trying to come up with a way to keep it cooler in there and not spend a ton more money on the problem. The best solution I can see is a Ductless Mini Split AC such as this:
Amazon Link
I know that I don't need a 12,000 BTU AC unit for the size of my room, but with the projector and all the equipment I want to go a little bigger so it doesn't have to work so hard.
So my questions are:
1) Does anyone here have one of these and how do they work? Any specific brand you recommend over another? (I've seen Mitsubishi, Lennox, Trane, Pioneer, etc...)
2) If you have one are they really as quiet on the inside piece as I've read?
3) Do you know if it would be an issue drilling through the foundation wall (in the basement) to run the pipes. It looks like you need a 3" hole for everything. My wife is worried since it is the foundation I'd be drilling through.
A bit more information on the room. Three of the walls are concrete behind the drywall, the only wall that isn't concrete goes into the rest of the basement.
Thanks for any input.
Amazon Link
