navicaph said:Heres mine. Liking it so far, but my Sony dvd burner doesn't fit in there.![]()
That_Sound_Guy said:I got mine and love it to death. The only bad thing so far i found is that the small holes next to the vid card dont meet the fan on your gpu so it chokes it up. When you put the case on while the fan is running you can hear it have to run much faster and harder because of restrictions. I will be cutting it out and meshing that area real soon. other then that all is good on stock BIOS.
omigod said:I have bulit one using Sony DRU-710A and all you need to do is remove the face panel and it will work like normal.
edit: from the photo, it looks like you have sony DRU-710A too. Just take off the face panel (dont break it). It is snapped on - just gently wriggle it free.
