Any thoughts on the case? Can anyone tell me if those front bezels can be removed so you can use a 5.25" drive without them? I'd prefer the look of the case without them.
I'm also really concerned with the general noise level from the case. My current computer sounds like a vacuum cleaner - something I'd like to avoid a repeat of.
Finally, any thoughts on the model with the side window versus without it? Is the windowed side solid or are there vents? If there are vents, does it have some device to prevent dust intake?
Thanks very much in advance, guys.
