anyone got a spair printer/LPT/parallel cable? 3ft-6ft?
MATTRESS
I'm looking for a high quality, shielded preferred, 3ft - 6ft cable. I don't care about the connectors, I will be cutting them off :)
Thanks!
yeah, ive got 2, dont even look like they were ever used.. look to be about 6-10ft long..
-Evil Juggalo
outstanding! do you know how good of quality they are? i'm trying to do a project with the faceplate of my headunit, and using 2 cat5 cables didn't work.. and i'd hate to run into the same problem.
do you have AIM? -- i kicked yer dog
email-- thelenm@comcast.net
ebay: 122333221
heat: alchs_box
forgot to list my info in first post.
what kinda project? I have high end parralel cables, I dunno why I bought the high end ones when I did though, like the time I bought the $35 Gladiator floppy cables not thinking I was only moving 1.44mb of data at the time. doh
i can send you one for $5 plus shipping, it's pretty thick and quality looking
I'm actually "extending" the faceplate of my headunit ...
if you haven't heard of that, here's my plan.
I'm building a "carputer", and in place of where the headunit normally goes, i'm going to put an LCD screen and slim slot loading dvd rom drive.
I'm basically going to hide the actual headunit in the glovebox or somewhere, solder each individual wire to the pins that connect the face to the headunit, and mount the face flush with my headliner..
I tried using some cat5 cable I have, but it came out garbage.. the wires were too stiff, I had to use 2 cables (12pins, 8 wires per cable..) and it just turned into a nightmare and didn't even work in the end..
so someone suggested using some kind of shielded computer cable ... and a parallel cable is the only thing I can think of that has enough wires, and is shielded, etc..
I hope that's interesting enough for you ;)
