Warrior said:yeah dude be respectful....i have no personal experiance..but i wouldnt change if i had the NU....cause of the features that the 6800 supports that the 800 dosnt..and its really easy to flash to a GT and get alot for your money. There is no need for better performance in source cause its a really smooth game anyways.
my 2 cents
Sizer said:If everyone was to be an annoying idiot like you and cry about looking at reviews then 90% of the threads here would have no point Stop it.
Sizer said:The ram is what rapes this card's performance. High resolution and/or AA in Source runs like garbage.
And by the time ps3.0 means jack, I'll either have a new dual core system or will have moved on to next gen consoles and forget about upgrading uber expensive computer parts.
palabared said:i have a 6800 nu and i think its the best videocard investment ive made. You can find them for around 240-250 now adays. With the sweet 16 pipe unlocker prog u can really boost performance too. Im not going to argue and 3.0 shit with you, thats your deal. I bet there are close to 0 people who made that switch. its not worth the extra 100-150$
Chaballaman said:i've used friend's gigabyte x800pro (16pipes stock) when they first came out but weren't impressed by it.. *snip*
Kckazdude said:Thats impossible, the X800 Pro is only a 12 pipe card.
