Title pretty much says it all. I have a 2gig 560ti 384 shader version that does a decent job for my resolution (19x10) .....but I would really like enough unf to keep me at 60 fps most of the time with detail settings on the high side. Looks like I can get another card for around the $265 mark....so I am considering it.
I have never run a multi card GPU setup. When they first got popular it seemed like they were more hassle than it was worth. Typically it was better to just buy a beastly single card...
Im not interested in selling my current card. Don't want the downtime in between finding a new card, and I lent out all my other decent video cards that I would use as backups.
Looks like I will be pushing the limit of my powersupply ( corsair tx650m ) if I toss another card in. I have a PCP 610 sitting around also to try for kicks if the corsair can't cut it. And in the end I can get another PSU if neither can get the job done.
My motherboard has x16 and x8 pci-e slots. Is the x8 going to handicap the extra card?
So, has anyone run a non 448 560ti card in SLI, and if so are you satisfied with your results?
If you think I am just wasting my time and should go with a single card, feel free to lay it on me. I really do not like buying the lastest and greatest in videocard tech because of the price gouging that occurs at that level.
