Only 7.5.9.0 and higher will work properly with Vista, so if the method I already described (which I discovered myself through trial and error over 4 Vista installs) fails, I'm not sure what else to offer as advice.
The first run i did not of course, but afterwards yes, Ive deleted everything nero on the PC, and have tried 7751 the newest and 7590I'm not running Vista presently, but as I said, 7.5.9.0 and higher are the ones that Ahead themselves say are Vista compatible. Anything else might work but those are the ones Aheads says are A-Ok for Vista.
I used 7.5.9.0 under both 32 and 64 bit versions of Vista, with no issues, as long as I followed the steps I laid out in the earlier post about installing it with Admin priviledges and doing the first run with Admin priviledges also.
