1. PacketFence does DNS/DHCP/InterVLAN routing, correct?
2. Should I put a firewall VM alongside the PacketFence VM? I was thinking of taking something like pfSense and run it in bridged mode to the PacketFence ZEN VM. Then PacketFence would handle all the DNS/DHCP requests.
3. The VLANs need to be specify on the switch, correct?
4. What NIC do you recommend for PacketFence? It doesn't have to be super fancy because this is for a home environment but it needs to be able to support VLANs at least.
Thanks. Gonna take a major dive into networking to try to figure out with this stuff.
