Sounds dumb I would imagine, BUT, I have no other choice.
For some reason, it seems that thermal pads are impossible to find in various sizes. Sure they are out there, but it takes forever to find them.
I was sent a thermal pad for a GPU cooler and it is too thin, as the chip and the heatsink and not touching. There is a gap there that is killing performance.
They supplied a 1.3mm pad, but it will need to be about 2mm to work perfect. Problem is, I cannot find any that size! I have some 1mm pads lying around and if I put one on top of the other pad it should fit fine.
My question is if it will affect the temperatures at all, in comparison to using a 2mm pad?
