anyone ever modded a Cisco Switch?
Jay_2
I have a 2900XL in my home server setup and the fan is so noisy I can hear it in the next room!
Has anyone ever modded one to make it quieter? Or has anyone replaced the fans in a Cisco switch? If so, any advice?
Also if I added a WS-X2931-XL modual for Gigabit Fibre Links would I need to change the ISO version?
Cisco Internetwork Operating System Software
IOS (tm) C2900XL Software (C2900XL-H2S-M), Version 12.0(5.1)XP, MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-1999 by cisco Systems, Inc.
thanks.
Its not that the fan I have is damaged, its just that those tiny fans make a lot of noise.
I have the same problem with my 1u 2900. The fans use standard fan connectors, I should just holesaw the top and fit a couple 80mm fans. in the top panel.
