TheBluePill
- Aug 17, 2005
In 16 Years of computer repair I have run in to a whole bunch of stuff, but this one has me scratching my head..
A friend of mine brings me a Gateway 500S PC with a bad hard drive. I replace the drive, reload XP and its drivers, test everything out and give it back to him.
He calls me from home to tell me that it wont boot, just has a yellow power indicator.
So I have him bring it back to me.
I check over everything inside and it looks like all of the connections are solid and nothing shook loose durring the trip. So I start testing components. I have quite a few known good peices laying around and swap out the AGP Video card, Memory, CPU and Power supply, peice by peice all with the same results. the only Component I don't have is an Intel D845HV mobo, So I figure there is probably something wrong with the board.
I order a new one up and install it for him with his origional components and I get the same thing. So I take out everything and put in an alternate CPU, Vid & Mem with no other devices attached.. Same Yellow Light. I swap out the PS, Same yellow light. I swap out a 3rd PS, Same yellow light.
At this point the only compoent that is from the origional system is the case.... So I put in a PS that has a "test" switch.. SAME THING...
With both mobo's stripped down to the CPU/HS only I still only get a yellow light...
The 110 Power, KB and Mouse are all good, So What In the world am I missing???
Help...
Help...
