I've got a HD 4650 in my HTPC. It's a got a grand total of about 0.1 pounds of anodized aluminum with a pathetic 30mm or so fan. Believe it's this model: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102907
It's not super loud, but I'm in the pursuit of getting my machine as quiet as I can without spending more money.
I had a passive card (HD 5450) in there, but I've got no case fans, and the passive card overheated, so I installed a 60mm Vantec Stealth on a fan controller, turned down all the way, in the case and angled it at the card, but the card didn't meet the minimum specs for WMC to use it for TV, so I had to upgrade to the 4650.
I looked at aftermarket coolers, but there's nothing designed for low profile. And I'm legitimately low profile, it's not like I have a low profile card with an inch or two of free space above it.
So I'm sitting there thinking, I can't go any wider, but why can't I go taller? The current heatsink is a relatively tiny single slot cooler. Even with the Vantec Stealth blowing on it, I still need to crank the GPU card to >30% in Trixx to keep my temps in the 60s. I don't need single slot, I've got a microATX mobo and no expansion cards, so there's nothing stopping me from using a 4-slot cooler besides one, you know, not existing.
So I grabbed an old P4 heatsink I had laying around, and I thought that if I cut it down a bit with the hacksaw, then drilled a couple holes in it to line up with the GPU mounting pattern, and mounted it with some machine screws and some springs, I could make a pretty badass passive heatsink that's actually big enough to function with only a little bit of case airflow. I mean, I could just go out and buy a lower power consumption latest gen low profile passive card (22nm should be a lot cooler than my 55nm 4650), but it seems to me like passive cards only have the bare minimum to get away with in a case with a substantial amount of airflow. My HD 5450 had a tiny TDP, but in a tight case without fans, it overheated like crazy. My 4650 is old enough and cheap enough for me to not be heartbroken if this experiment goes wrong, but I wanted to see if anyone had done a similar project and might have some tips. I figure that most of a big P4 heatsink should be plenty with just a whisper of a breeze from the Vantec Stealth.
