anyone after 42" heaven?
clayton4115
42 Inch LCD HDTV Ready Monitor / 1080p Capable / 16:9 / 1000:1 Contrast Ratio / 1920 x 1080 Resolution / 550 cdm2 Bright
The new Westinghouse LVM-42W2 Digital 42" 1080p Monitor was designed to match the way you view high-definition. Its 1920 x 1080 Resolution display with over 2 million Pixels deliver a viewing experience that's almost like being there. Introducing the exciting new Westinghouse Digital 42” 1080p Monitor, designed specifically to match the way you view High Definition content. This is the only display that should be connected to your HD cable box, satellite or multimedia PC! The LVM-42W2 includes a pair of 10 Watt speakers and an Integrated 10 watt Subwoofer for a Sound experience that makes you feel like you're a part of your favorite shows and movies. Specifically optimized for use with the latest high definition sources. Don’t be trapped with only 1-choice. Westinghouse lets you attach all your favorite sources using uncompressed highest performance digital interfaces. Multiple high-bandwidth digital-interfaces mean you can have HD digital cable, HD satellite and a digital game console. Additionally, Desktop and Notebook PC users can enjoy the same fat pipe and the industry best Genesis Display Perfection technology.
42" 16:9 widescreen with up to 16.7 million Color display
Contrast Ratio: 1000:1
550 cdm2 Brightness
Viewing Angles: 176 Degrees Horizontal and Vertical
Compatible Modes: 480i, 480p, 720p, 1080i, 1080p
Native/Optimum Resolution: 1920 x 1080
Supported PC Resolutions: 1920 x 1080, 640 x 480, 800 x 600, 1024 x 768
Twin 10 watt speakers, with 10 watt subwoofer
Picture-In-Picture
Inverse 3:2 pulldown
Freezing Picture
CCS (Cross Color Suppressor)
3D Noise Reduction
3D Video Processing & 3D Comb Filter
Response Time: 8 ms extreme rapid response for playing high-action videogames
Connectors: S-Video, Composite Video, HDMI-HDCP, DVI-HDCP (2), YPbPr Component Video (2), VGA/D-Sub/RGB, Audio mini jack
Lamp Life: 60,000 hours (about 27 years based on 6 hours per day viewing)
Installation Options: 8 Hole pattern, 75mm x 75mm VESA pattern, 100mm x 100mm VESA pattern wall mounts
Progressive Scan
Aspect Ratio Conversion
Color: Silver/Black
Dimensions(HxWxD): 25.8" x 41.5" x 4.5" without base / Dimensions With Base: 28.0" x 41.5" x 9"
Weight: 52 lbs. without base
Weight With Base: 57.3 lbs
