Anybody running on nicehash.com??
kerbos5
If so what are your thoughts...... decent profits?....I just started a test so jury is out with me still.
I mine on nicehash just because nicehash control makes it super easy to set it and forget it. On my 6x750ti rig over the last 5 days I averaged .00678 btc per day. Not really great, but i'm not sure you can do any better by straight mining/ converting to btc in the current market.
You would probably make more playing pump and dumps with alt coins
You're not going to get decent profits mining anything anywhere at the moment, its the worst time for profit.
As far as Nicehash goes, the idea is good and the multi algo switching is handy, but their connections always coincidentally drop during the high paying spikes, pisses me off.
What about magicpool.org, I have been on NiceHash for about 3 days, its not bad..... I love there new nicehash control toolkit, comes in handy....is there any pools/service that you guys recommend.
Yup, doing the same. Now that Jackpotcoin is solidly in the throes of a long, slow death, I this is definitely the best "set it and forget it" option.
Right now Vert has a good balance of exchange rate and volume. X11 to keep things cool.
Someone suggested:
http://x11.greenpool.tk/
But you're still losing.
I mined on greenpool for ~28 hours on the x11 URL with my Vertcoin wallet address, got 5k or so accepted shares from the rig I was testing it on but never got a payout even though the greenpool miner URL showed my hash rate as 20mhash/s.
Never got a payout for a share, ever. Think I'm going to stay away if someone who's been mining for three years and has used pretty much every multipool imaginable can't figure out what he did wrong.
What does this tell you?
http://x11.greenpool.tk/address.php?address=<vtc payment address>
Vertcoin explorer
http://explorer.vertcoin.org/address/<vtc address>
Check your vtc wallet debug log too.
%appdata%\Roaming\Vertcoin\debug.log
Vertcoin explorer
http://x11.greenpool.tk/address.php?address=VhzdSD1tiTKsWmi2ydA1PMSfS1Xp5eq5Ld
That address has not submitted any valid shares to this pool.
..dunno. I was using Pimp with the x11mod and had just switched from DarkCoin so I know it was working. I was connected to stratum+tcp://x11.greenpool.tk:3333 with no rejections. I didn't really babysit it, I entered the new URL and switched the rig over and then checked it the next day. Saw I was not getting any shares and had zero payouts but the entire config seemed correct so I just shrugged and moved on.
eh, I went with nothing for a day, Moving on.
Nicehash was doing okay the past couple days, but now back to bottom of the barrel rates, gotta find something else to mine.
