download chrome... favorites are saved in the cloud and uploaded to any device you use..yeah. since win8.0 I been preoccupied. but now that ms has its two feet on the earth again its a releif. when I am on the Linux browser the thing i mostly miss is my ie favorites bar collection of links!?
what do you guys miss on Linux that only windows have?
I've spent five hours yesterday trying to get qtcreator and cmake to run. Pulled my hair out and got nowhere in the end. First SimplyMEPIS failed to install them because of some unresolvable dependencies. Then I managed to install them on Mint 16 only to find out that a newer (and only available in repositories) qt has problems with cmake and wishes to configure some kits of which neither I nor Google new anything about. Then I somehow managed to install an older version manually, but multiple other errors started appearing because my cmake installation was missing some files that my friend's Linux had for some reason. Gave up in the end.
It would be helpful if you indicated what you're looking to do with your system. Folding, Security, OS Familiarization...
i wish Linux was as easy to use as windows is. like trying to install a simple thing like my video card driver. and even before that, how i am supposed to know which driver my distro uses.
i wish my mobo manufacturer supported Linux. most of the hardware (keyboard, mouse, monitor, printer, etc.) they mostly don't support Linux, i like having the most up to date drivers.
I hate Linux with a passion.
Off of the top of my head: visual studio, office, powershell, SQL Server management studio and all of the tools that are associated, Notepad++, Araxis merge, Adobe CS, etc.
There's a fairly long list of things, and the longer I sit there and think about it, the more stuff that bubbles up.
I'm sick of loading up junk distros like Ubuntu only to find that it didn't come with binutils (seriously, though, why wouldn't you ship binutils? GCC/G++ is useless without a toolchain)
or that they've switched over to some unofficial Nvidia driver called Nouveau
It is not meant for cry babies or people who just "give up".
I am sorry that giving up five hours of my free Saturday isn't l337 enough for you. I guess I should have persisted and spent my whole weekend just to make one program run.
Or take 5 minutes of your time and ask for help. If a noob spends his day trying to do something he cannot grasp, it is no one's fault but his own.
Why would you needs these in a Linux environment?
And you honestly miss powershell? Really?
It's right there in the software center.
That's a legal limitation.
is ms right when they say that there is only windows and nothing else worth it? what is a only hope then? mac os x?
are Linux and mac os x the same type of os?
I might get called picky for this but Linux is not an OS, it is a kernel. OSX is based on a different kernel called Mach which is a BSD. I'm not sure what you are asking by saying 'the same type'
Installed by default would be a much more intelligent option.
No it isn't. The only legal limitation is that they can't ship Nvidia's proprietary drivers. There's nothing stopping them from shipping it on VESA drivers like any other distro. If they want to make things work more accessibly for the bag-o-rocks type users who can't figure out how to install display drivers, their efforts would be better spent making their 'proprietary driver manager' work more reliably rather than developing a cruddy open-source driver. The nouveau drivers add a couple extra steps that must be completed before you can switch over to real display drivers, and since the nouveau drivers are too slow to compete with the real drivers anyways, it's just something that does more harm than good.
Had audio issues with Ubuntu and the audio service pegged out one of the cores. Tried Linux Mint and everything worked great out of the box. Used universal installer to create a bootable USB stick with persistent storage that allowed video driver installation, software installation like Chrome, Unigine benchmark, etc. and kept settings between reboots.
http://www.linuxmint.com/
http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
Why do you feel like installing a compiler toolchain by default is an intelligent option for a desktop OS? There is a limited amount of space for them to fit it on the DVD, why would they ship with something like that packaged at the expense of things more suitable for ordinary users?
Do Windows and OS X ship with compiler toolchains pre-installed?
It's so hard to go to "Additional Drivers" system setting and click the big flashing "install nvidia driver" option then let it reboot?
You want them to run the desktop on a VESA driver that does 1024x768...?
Are u satisfied with Linux, besides games, what do you guys miss on Linux that only windows have?
Linux has games on Steam. I game under Linux just fine.
Because it's small, and unless you're only using your computer as a giant web browser you're inevitably going to need it.
No, but they also don't ship with a compiler, so there isn't a need for a toolchain, and you also don't need a compiler with a toolchain in order to install typical software (display drivers, for example) like you do on Linux.
No, but it is difficult for unskilled users to fix their X11 config when the 'additional drivers' menu breaks it and their system fails to load X11 and boots to a command line.
Yes, because then it only takes a second to kill the GUI and build in proper Nvidia drivers, rather than having to remove the Nouveau kernel module which gets in the way of the Nvidia one first.
The correct solution there is to fix bugs in the driver installation program, not force users to install the driver manually.
You're really arguing that it's easier for somebody to drop to a console terminal, close down their DE session, close down X, install all the requisite build software and kernel headers, and install from the command line and reboot... than to just press a "Install NVIDIA driver" button in the Additional Drivers window?
Besides, the VESA driver should technically be blacklisted too since it's not compatible with the nvidia driver. I find that it mostly works with both loaded, but there are occasional issues, and nvidia's official stance is that the two should not be loaded together.
Exactly...correct the problem, not try to make your own open source drivers that the system can ship with by default.
Not even Nvidia's README makes any recommendation to remove VESA. However, the Nouveau module must be removed for the Nvidia install to proceed. These are not the same situation.
