I recently retired my WRT54G and replaced it with a WZR-HP-G300NH.
I'm still tinkering around with it and i don't know if these are normal.
- Maximum file transfer over LAN is 30MBps? Is this as fast as it'll go?
- Maximum Wifi transfer over Wifi is 11MBps/3MBps UL/DL? Is the uneven bandwidth normal?
- When i enter my internet IP, i get sent to the routers setup page "Permit Configuration from wired Internet" is already disabled but outsiders still have access to the router. The checkbox for it on the WRT54G atleast works, or is there a different place to set it on the buffalo?
- Can't seem to get port forwarding to work. I've set it up on the WRT54G and i've been hosting some test websites, but i can't seem to get port forwarning to work on the Buffalo.
- With port forwarding "running". When i enter my home ip (i.e. 555.444.333.222), the routers setup page gets run instead. Even if i use the forwarded :80 port( ex. 555.444.333.222:80 -> 192.168.1.100:80), it only opens the routers setup page. All other ports return an error. Even if i were to say that "80" is supposed to go to my IIS server, it will only open the webpage of the router.
Did i miss a checkbox somewhere? The interface is different from a linksys so i'm still figuring out where everything is. On the linksys, no matter how much you set, there's single checkbox separate from everything that has to be toggled to actually get port forwarding to work, is there an equivalent for the buffalo?
