Executioner
Older Than FrgMstr
- Apr 22, 2015
I know you are not suppose to defrag SSD's, but I was having sluggish performance from mine. I checked using windows 7 defrag tool, and it stated it was fragmented by 40%. So I figure what the hey. Afterwards, it ran just like it did the first time I installed it.
I know that the SSD Trim is enabled as I checked it with some utilities. The only issue I have is with the windows 7 gadgets. After the defrag, then don't load automatically anymore due to how fast it boots to the desktop. I get them to load by simply right clicking on the desktop and select gadgets, and then they show up but not at boot up.
I did find a batch file that I found on the net that delays the start until the desktop is fully displayed.
