Any worthy upgrades?
Kil4Thril
I'm using 2 7800GT's in SLi, and I was wondering if there are any decently priced single-card upgrades at this point. I won't build a new machine until next fall, so a GPU upgrade should keep me smooth. It'll be on h2o, and running at 1920x1200. Right now, they get killed by Call of Juarez :( I'd like to stick with eVGA unless an ATI card is the recommendation.
Decently priced?! Basically, what single-card upgrade will hold me until refresh/dx10/new build.
bro you have 2 7800gts .. are you hurting for frames?
probably 2 7900gtx's would be the next step
the 7900gt's wouldn't be worth the switch i don't think
maybe 2 7900gtx 512mb's would do the trick
Yeah, CoJ is owning me at native resolution. Maybe I'll see if I'm happy at lower res, or switch monitors (12x10 19" instead of the 19x12 24") to hold onto the dollars until a full build. I would like to hold about 9 months to a year.
I would think you'd be okay, just don't crank up AA or AF or super high textures because of the VRAM being lower.
