My computer is in a completely seperate area of my home then my home audio system that feeds the entire house.
I wonder if there is a device that will take audio output, convert it to IP traffic, send it over my LAN, and then take that IP traffic and reconvert it to standard audio near my receiver so I can than plug into my home audio gear.
For example, I have a small box that sits near a remote serial device. My PC runs a little driver that intercepts all outgoing COM traffic and converts it to IP. It then send it to this little box that has its own IP address that sits next to my remote serial device. The box, which has a serial cable and plugs right into serial device, then "decodes" the IP traffic back into serial.
I pretty much need the same thing for my audio output in XP.
Thanks!
Wazoo
Thanks!
Wazoo
