Any way to minimize Doom 3?
Regulus
It's really bothering me that I can't just alt-tab out of D3 when I need to check something on the desktop or read off a console command. Has anyone figured out a way to minimize D3 to the desktop? Alt-tab and windows key+D do nothing..
it alt tabs out for me, but it stays in whatever resolution its in and doesnt give back the mouse. I wish games would be friendly to alt-tabbing.
If it doesn't give you the moust just pres CTRL+ALT+DEL and the manager will come up. Should give you back a mouse, then just close taskmanager.
Try ALT + Enter and if that gets it out of fullscreen. Then hit ~ to bring up the console and it should free your mouse
Rel
you can try the microsoft compatibility toolkit and remove the no alt tab entry for the executable i assume as well. if i can ever manage the cash to pick mine up from gamestop ill give it a try and let ya know
trying this now...
edit: nm, the alt+enter and console trick worked perfectly, thanks Relic!
