Any way to fix this?
Larson2042
I've narrowed my problem down to the fact that the IDE drives in my computer don't want to work nicely along side the newer SATA boot disk. They had been working together fine, but now whenever I try to access something on either of the two IDE drives, I get a BSOD with the error ***STOP: 0x0000009c (0x00000004, 0x80545ff0, 0xb2000000, 0x00070f0f). So, there is apparently some sort of conflict in the hard drive controllers somewhere, because the problem goes away if I unplug both IDE's. So what I'd like to know is if there's any way to fix this problem through some sort of driver update/bios setting/something other than swapping the entire motherboard.
Full system specs:
Athlon 64 3000 (Venice core)
Gigabyte GA-K8NU-SLI
2x 512 Corsair value ram
2x 6600gt
SB Audigy
Sata boot disk: 160GB Seagate
IDE's: 80GB and 160GB Maxtors
are there any BIOS updates available for your board that could solve the issue?
There have been problems with certain nVidia nForce drivers. Are you using native Windows IDE drivers, or have you loaded nVidia's IDE drivers?
Most recommend to not load nVidia's IDE drivers.
Well, I unistalled the nvidia parallel ata controller, rebooted, and apparently windows just reinstalled the same thing, but it appears to be working just fine now. or at least the things it would crash at aren't crashing anymore. if it happens again, though, i'll have to figure out how to make it use different drivers, i suppose. thanks for the help.
