Nasty_Savage
- Mar 19, 2001
I know this may be a pipe dream, but it sure would be nice to build a cheap/powerful VM host with an 8 core proc...anyone know of any?
http://www.kingston.com/dataSheets/KVR16R11D4K4_64.pdf
These kits are a bit expensive and I do not know if it will work, but damn that is a lot of memory.
I highly doubt registered memory will work with any current desktop system or CPU even for AMD.
Not for a while most boards will support 4 DIMMS up to 32Gb for the moment.
At 16Gb and frankly that's overkill.
wrong amd cpus support registered memory with out issueI highly doubt registered memory will work with any current desktop system or CPU even for AMD.
if you want more mem/cores look at the opteron 6300 series with a dual socket g34 board with plenty of dimm slots and a lot of other useful features as well
