Any UK Modders
$h0ck3r
hey guys, is there any UK modders here, by that i mean that is there any people here who mod their PC from England, well i want to spray my case etc. but most of the tutorials on painting it apply to US only, so i cannot just pop down the shop and buy some, im after somewhere in the UK i can get some paints to paint my case, e.g. primer, main, and clear.
thanks in advance
thanks in advance
Not trying to sway or incite a mutiny on these great boards, but i consider these forums as my 2nd home.
If your looking for the best/biggest/well known UK modding site/forums go to Bit-tech.net
but remain a member here also as its good to get opions on both sides. :D
Im from the UK and painted my own lian li pc 75 case. I did a worklog to show it as well. Heres the link below:
http://hardforum.com/showthread.php?t=1053059
I have also written a guide to show how to paint your case exactly. PM me if you want to see it. Well depends on what finish you what. Where abouts in England you from? ill recommend you some places to buy your paint. I had the same problem as well where to buy the paint and supplies as the UK isnt to the US standard yet in terms of finding everything you want so easily.
