Any tutorials on how to improve a webcam image???
Discussion in 'Digital Artwerk' started by Metallica_Band, Jan 13, 2005.
  1. Metallica_Band
    Metallica_Band 2[H]4U
    3,437
    Oct 23, 2002
    Hey there...ok...I have this webcam image...webcam images are small and they tend to be grainy and the colors aren't that vivid...kinda like someone took the saturation down or something...
    So I was wondering if there was a tutorial that could make a webcam image better...any ideas???
    THANX
    C'YA :cool:
  2. theDot
    theDot 2[H]4U
    2,408
    Jun 7, 2004
    Webcam images are generally jpeg's ... so, I really don't think it's possible to improve the image quality too much.
    Of course, you could try playing with the levels and color saturation in PS all you want, you may get some slight enhancement.
  3. DoMeHardR
    DoMeHardR Limp Gawd
    227
    Oct 16, 2002
    10 bucks says its porn
  4. Absentee
    Absentee [H]ardForum Junkie
    9,416
    Aug 27, 2004
    i see your $10 and raise you $20
  5. BossNoodleKaboodle
    BossNoodleKaboodle [H]ard|Gawd
    1,818
    Dec 6, 2004
    I'll raise you fifty and anyway all you can do is despeckle it with PS and then maybe try a diffusion filter if you increase the DPI.
  6. Bobby
    Bobby Limp Gawd
    275
    Aug 26, 2004
    Techniques on improving such images varies a lot, so how bout you post it here, and we'll see what we can do ;)
