BellaCroix
- Mar 25, 2004
Anyone have any suggestions on how to get an (approx) 1/16" wide cut through aluminum?
Every jigsaw blade I've seen is below 1/32" and Dremmel disks are even thinner than that. Circular saw blades are pretty close but I've never heard of using a circular saw on a case sidepanel.
If it helps, what I'm looking to do is to mod a piano hinge (also called a continuous hinge) into the side panel of a case I'm working on. If you're familiar with them you have an idea what I'm talking about, they are shaped sort of like: __o__ and I'm trying to get the round part of the hinge to fill the gap cut out by the saw.
Any ideas what could cut out that size without a month with a hand file trying to widen the cut from a jig saw? Yes, I know two passes with a laser cutter would do the trick but my laser ray gun is out of dilythium crystals.
Thanks!
Thanks!
