Any such thing as 2k 32 inch 144hz gsync monitor
I thought I had seen an Acer that fit this set of requirements but it looks like I was mistaken.
Yeah there is an Acer and some others at this size but for now these are all 1080p.
The 31.5'' 1440p 144Hz monitors probably won't be released until Q2-Q3 2017.
btw. 2k is 2048×1080
Yeah, I think for PC resolutions we need to refer to the HD designations if we don't want to directly state the vertical resolution.
SD = 480
HD = 720
FHD = 1080
QHD = 1440
UHD = 2160
UHD+ = 2880
Um no, there is one that is 4K 32" with G-Sync but it's only 60hz
Acer Predator XB321HK 32” IPS NVIDIA G-sync Gaming Monitor Black 32” 4K UHD 60Hz HDMI DisplayPort-Newegg.com
So far, it's all a compromise.
The best for what I want is the ASUS and ACER curved 34" monitors, 3440x1440 at 100hz at 21:9.
They aren't perfect but I think they offer the best of everything that's available.
I'm sure that it's hard to go back to 60 or 75hz after using 144hz. But I think I could live with 100hz to have an ultra wide 34" curved display at 3440x1440.
I meant the 144Hz Acer Z321Q, with a whopping 70ppi. Acer did not advertise the resolution so some hoped it might be 1440p (but those panels aren't ready yet)
