Hi!
I'm a long time [H] reader, but first time poster here and I hope some of you savy people might help me in my search for a case.
I have some specific needs that kind of limit my available choices and I haven't had much success finding a suitable candidate on my own.
So yes, what are my needs? Well, here goes:
Again I would really like a side fan to blow air onto the graphics card and my RAID controller.
And yes, I need that many harddrives.
A bunch of them running in RAID for video and such work. This is probably the main thing causing so much trouble, as there aren't a whole lot of cases supporting that many harddrives.
I did find the Fractal Design Define XL, but after reading a bit about it I've kind of given up on it for various reasons.
The bottom chamber has barely no exhaust option, which worries me. With 6 drives down there and a PSU it will get pretty hot.
It's a bit cramped (with EATX boards) and the cable management could be slightly better.
It should be noted that I also need to install a DVD drive in the front, so harddrives can't take up all the external drive bays.
I don't really have a budget. I know a case like this won't come cheap and I'd rather spend some extra money getting what I want than settle for something I'm not satisfied with.
I think that's about it. Thanks in advance for any suggestions.
- Needs to support 9 harddrives (7 mechanical and 2 SSD's).
- Good cooling options are a must.
- I would very much like a fan on the side of the case to blow air onto the graphics card (and incidently my RAID controller too).
- USB ports on the front (or top). Some USB3.0 ports would be lovely but not required.
- Ability to have more than 1 exhaust fan in the back (or top). As I will install a Corsair H80 cooler blowing in, some exhaust fan(s) would be needed.
- Support for EATX motherboard (as my motherboard is such a thing).
- Good cable management options.
- Nice looking. I don't want lights, transparent side panels and such things. Just a clean looking tower, along the lines of the Lian-Li PC-A71F that I have now. It doesn't have to look exactly like that, but it kind of gives you an idea of what I like.
