Any recommend a good screwdriver set /w small bits?
Hunterzyph
I'm not exactly 100% on the terminology, but my current replaceable bit screwdriver set is a bit of a joke, low quality, and the bits don't fit the smaller screws I run into.
Any recommendations, or clarification on the terminology for assisting me with my search?
well... what size of screws are you trying to take out? Torx, phillips, flatheads? (I'm going to guess not flatheads.. you can take those out with anything.. :))
take a trip to sears or home depot, get a good craftsman or husky with a replaceable tip/bit.. take the screw(s) with you and try out the various bits..
