Any problems with this?
MrDude010
I want to buy an 8800 gtx and I also would like to water cool my next case. Danger Den is the only place I know of that sells a waterblock for the 8800, would sticking a danger den component in with aqua computer components be a problem?
Nope, as long as all the parts use the same size tubing, or else you'll have to get hose adapters. Also, don't mix copper and aluminum in a loop, though I don't think you'll be using any aluminum in an AC/DD loop :).
I think the reservoir is anodised. If it is, there won't be any corrosion.
