Any other IB chipsets besides Z77?
JJ Johnson
I'm looking for a microATX motherboard that will probably be used for a non-overclocked Ivy Bridge processor like an i5-3450 or 3550 and a single discrete GPU. Most of the Z77 motherboards available appear to be overkill. Has Intel released any other chipsets recently? I do like the USB 3.0 headers on the Z77 boards, but not much else makes much difference.
There are the other x7x series, as well as most x6x that have BIOS/UEFI support for IB. Lots to choose from.
I would recommend just getting the Z77, though. Even if you never use some of the features, at least they're there...just in case. Besides, the price spread isn't really that large.
I agree with all of this, especially considering Z77 mATX boards can be had for $110 and up, but there are some other IB chipsets.
Z77 - http://www.newegg.com/Product/Produ...&name=Intel Z75/Z77&ShowDeactivatedMark=False
H77 - http://www.newegg.com/Product/Produ...DeactivatedMark=False&Order=PRICE&PageSize=20
B75 - http://www.newegg.com/Product/Produ...DeactivatedMark=False&Order=PRICE&PageSize=20
Also, Z75 boards should be showing up sooner or later.
Yeah, you can do a web search for Intel chipset comparison. Also check the Intel ark site.
Is there a guide anywhere to Intel's numbering/lettering scheme for chipsets?
I echo MissJ84. The difference between the Z77 and the Z75 is that the latter omits Intel's SRT SSD caching feature. But if you're going to simply use an SSD as your OS drive, then it doesn't matter. The SSD caching feature benefits only those who use a conventional HDD as the OS drive but use a very small capacity SSD for caching.
What is the difference with the Z68 chipset motherboards? I bought one of the Asus boards mainly because it would "support" IB. Was this a bad move?
