First the disclaimer.
Yes I know it's my fault for toasting the CPU.
Yes I know it was the risk I took with over clocking.
No I'm not crying over it. You have the pay to play sometimes.
With that said it seems my E6400 has died. I'm having a friend put it in his rig to confirm it but I have changed or tested everything other then the CPU. Ram was tested and works, mobo changed, PSU changed etc etc..
I overclocked it to 3.5ghz and was running fine on water but after it died and I took it apart it looks like I might have made a noob mistake and put the AC5 on a little too thick. In any case I think it's toast.
I just got the CPU from Newegg.com on 5/2007. Now my question is do I have any options on seeing if I can get it replaced or should I just make my son a necklace out of it?
This is what I got..
Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail
