So for a long while I would have liked to place all of my media files onto a NAS but my original thinking was to procure a chassis large enough for multiple 3-4TB drives so that I could place them into a large RAID6 array for some degree of protection.
Well, recently I got to thinking about it again and realized it wouldn't really matter if I had RAID6 because even if a drive failed I could replace what was lost on it rather easily. So in taking this approach instead where I would simply just have multiple drives connected to the motherboard, this seems easier and cheaper since I wouldn't need a RAID6 controller.
However I am still faced with one problem. Currently my media files that are stored on hard disks are offline a majority of the time, as in not powered up at all. If I built a nas and threw all of my existing hard disks in there, I would need some kind of advanced power management.
What I had in mind was that the PC/NAS itself would remain in full sleep mode almost all of the time, as in everything powered down. When it received a request from my media player hitting its IP address, this should wake up the machine and ONLY power on the hard disk that the player is trying to read. I want to keep the hard disks powered off at all times unless specifically needed. As the drive is online and the player is reading the files, once the player has finished and is shut off, I need the drive to power off within say just a few minutes. That means everything, the hard drive, the cpu, the cooling fans, etc.
I tend not to use applications like Plex or Windows Media Server; I simply have the files within subdirectories on the disks ready to be read.
So that's basically the scenario I envision. I admit I've never had to work with Windows before under such circumstances so I have no idea if it's even capable of specifically doing what I'm looking for. I also don't know enough about Linux power management capabilities either.
