Any one is using HEC Orion 585W ?
I got a post below. I am not really able to give a complete review. I need a multimeter to check rails and I won't really be able to stress this thing out too much ( 6600GT, 3 HD's, 3 Optical, 6 case fans, with an A64 Winchester 3500). It is a reasonable PSU for what you are paying. Someone like JonnyGuru with real equipment (and know-how) should bench it. It would be a real service to the [H] Community at large...
I have one. But don't use it. But i do use it as a tester of products, ect.
It runs quiet, the wires are a bit on the short side. But i did at one point run my entire computer on it once and it held up.
What i really want to know about this unit is the actual wattage on the 12v rail. 19A and 20A on the rails.
I've done popped this PSU open as well, not much to talk about.
do you recommended me this power for this system
AMD 64 3400+
K8N NEO
2X1GB DDR 400
GeForce 6800Ultra
3x WD 250GB
5x 80MM led fans
1X DVD Writer
1X CD Writer
I found that this power weight 3.80LB is that good weight ?
Please any one can test it and if possible open the psu and take some screenshots inside PLZ
