Robertmarcus
- Jun 4, 2012
Hi [H]. I'm making plans for a future case project that i will be doing in the summer and i had some questions about cost for a CNC machine since i dont trust myself doing such advanced cuts. The case itself is 100% aluminum, and will look a little like this. (http://forums.guru3d.com/showthread.php?t=365125) except bigger, i have a 1080 rad and a 1600w psu going into it. I wanted to know about how much this would cost. I plan on using 1-3mm aluminum, depending on which i think looks better. I live near a CNC shop in danbury CT, so shipping should not be a big deal.
To end,
I will be designing in Google Sketchup (do CNC shops use that, or will i have to learn autocad), and using 1-3mm aluminum. For the bars that you see on the examples case, will CNC's cutters cut those or will i have to do that myself?
Thanks
To end,
Thanks
