G'ßöö said:why are ya waiting? what's out now is just as good if not better ... nf4 has only a few things different over nf3 if you even need them...
personally I can't believe why the built in firewall took so long 2 B implemented and whoopie about the hype on it. who needs one now. so many would have other things in place for firewalls...wee late IMO but I am sure it would help someone
|NOLAFF|-JD said:Well dual core CPU is completely different! It's one cpu, but with dual cores on it, one chip stacked on top of the other plugged into the same socket so it doesn't require another CPU slot. Best of all is that if you have a 939 board then you will be able to simply upgrade to a dual core chip (probally require bios update too). So that means that the SN95G5 can support dual a dual core chip. As far as getting dual PCIe slots, well it wouldn't be very hard to do, but you wouldn't have a slot for anything else. I have to say that if shuttle doesn't try to do this with a future small form factor model then they will surely be dropping the ball on being the creative ones because some one else will.
I mean think about it, they currently have an AGP and PCI slot, so why would they not be able to do away with the AGP all togther, and make it as well as the other PCI slot both PCIe. I think there is enough room for this to be done in the P series XPC chasis. Also just because they currently have no plans to do this doesn't mean that some are not in the works right now!
IceWind said:Shuttle has stated they have no plans for dual PCI-E or CPU cores as that would negate their purpose of building small, yet functional and fast systems. Adding a second PCI-E and CPU slot would result in a larger case designs, more power requirements and thus it would basically become Mini-ATX and no longer a SFF and thuse negate the selling point of its XPC line.
|NOLAFF|-JD said:Shuttle is going to offer a SLI solution soon. It just so happens that my lanparty which is sponsored by shuttle has recently had a representative register on our site, and he stated in one of his post "Look for Shuttle to offer a SLI solution this coming February or March 2005." That looks like they must have plans for releasing a SLI system to me. The shuttle rep also said "The Shuttle SLI solution will come with the 2 PCI-x slots." All of this was brought up while we (the shuttle rep, and various site members) were talking about the new shuttle XPC that was recently released (The new BTX one).
JGene said:I too am waiting for SFF 939 + PCIe. I'm currently running a Shuttle SN45Gv1 with a Barton 2500+ @ 2000MHz and a GeForce 6800GT (ultra bios). I would get a nice speed boost if I upgraded to a SN95G5, however since I'd be running the same video card, my video games would be faster but they would look absolutely the same. That and the growing pains currently experienced by SN95G5 users make me somewhat heasitant.
I'll wait for a 2.8GHz Athlon64 with 1MB L2 cache and core revision "D" or later (adds SSE3 but still no HyperThreading). Dual-core would be nice but I don't think we'll see that on Socket-939 until about Q4'05. That and AMD is currently predicting that you'll see dually chips with core speeds that range between 1.8GHz and 2.2GHz. If you want a performance estimate on how they run go look at a Socket 940 board paired with an Opteron 244-248 with only one chip that has access to the memory.
Personally a 2.8GHz Athlon64 with a GeForce 7800 PCIe and 512MB ram would be a substantial upgrade over my old fashioned Barton and GeForce 6800GT. I'd like to run Doom III (and Quake IV) in ULTRA mode at 1368x768 at 4xAA, 8xAF at 60FPS (now HQ mode, 1368x768 2xAA, 8xAF ~45FPS). Until I can find a system that can do that in an SFF package I'll wait.
|NOLAFF|-JD said:Yes the Falcon Northwest SFF does have PCI-X, but here is the key and that is it's only 1 slot PCI-X! That means no SLI, and by looking at the pictures that baby doesn't look to be all that small. Friggin thing has a 500 watt power supply, and well thats pretty dam bad ass, but power supply isn't everything. After reading about the new SFF from Falcon I'm not sure calling it a SFF is really what they should call it. It should be called a customizeable small computer. Dam thing is 2 inches wider, and 2 inches deeper, and that power supply is a full ATX power supply. I think they created a whole new bread of SFF. It should be called a LSFF, or large small form factor!
umm... did you even finish reading what I wrote earlier? The FragBox 2 is the first 939 PCIe based SFF, the guy started the thread asking for one. There was no mentions of SLI until someone else came along and mentioned it. I went on to add that because the FragBox 2 case is not using any proprietary hardware, you can upgrade to a SLI micro-ATX board when it becomes available as opposed to waiting for Shuttle and buy an entire case/PSU/CPU cooler/motherboard combo box all over again. So wake up people!|NOLAFF|-JD said:Yes the Falcon Northwest SFF does have PCI-X, but here is the key and that is it's only 1 slot PCI-X! That means no SLI...
Agreed, R O F L, is that new fragbox still SFF? If so, I'd like to put a handle on my PC65 and call it SFF.
Shapeshifter said:If you were to toss in a Xp-m 2400-2600+ you could probably at least get 2.4ghz out of it, you would notice a good speed increase. wouldn't even cost you much.
