Any luck OC a 9800XT
I've read around some but can't seem to find any good info about anyone OC a 9800XT and seeing some huge results. I have played with RivaTuner some and only saw about a 100 point increase in my 3dMark05 score. Anyone know any decent speeds for the core/mem??
If I clock my 9800xt more than 3 mhz above stock speeds it starts artifacting. :(
It really depends on what card you have. I have a powercolor 9800xt and have it clocked at 440/396(non DDR) and it is stable with 40 min on RT HDR IBL (real time HDR tester) max load. It is air cooled and the case is open with a fan blowing on it. Works well.
Jeff
oc result in my sig... very minor performance gain
these cards are not worth ocing unless you absolutely have to oc for the sake of oc :D
